It is currently Mon Aug 11, 2025 2:30 pm
 Post subject: Bridge finish?
PostPosted: Thu Aug 18, 2016 3:24 pm
Just wondering what everyone does with there finished bridges
Finish,grain fill,just sand to high grit?
Mines ebony btw
 Post subject: Re: Bridge finish?
PostPosted: Thu Aug 18, 2016 4:20 pm
Remember that one day your bridge may lift and need to be carefully removed and reglued. Heat is used for that making finishing the bridge not a serviceable thing to do.
I micro meshed mine or buffed them out and then used Howard Feed-n-wax if I wanted to condition it and pop figure.
These users thanked the author Hesh for the post: kencierp (Fri Aug 19, 2016 8:46 am)
PostPosted: Thu Aug 18, 2016 4:21 pm
I don't finish mine...
PostPosted: Thu Aug 18, 2016 4:27 pm
Last Name: Kincheloe
Sand, shellac, micromesh. Open pores. Only takes a few minutes. No worries if it has to be redone after heating to remove the bridge.
PostPosted: Thu Aug 18, 2016 4:30 pm
"0000" steel wool and just a touch of Min-Wax "Hard Finishing Wax" wool buffing pad.
Ken Cierp
PostPosted: Thu Aug 18, 2016 4:54 pm
City: Escondido
Zip/Postal Code: 92029
I sand up the grits to 2000. Nothing else.
These users thanked the author rlrhett for the post: kencierp (Fri Aug 19, 2016 8:47 am)
PostPosted: Thu Aug 18, 2016 4:55 pm
Last Name: Waszazak
City: Vancouver
State: Wasington
Zip/Postal Code: 98665
Open pores. Micro mesh. At times I've used Tru-Oil or Tried and True. I think using something light is nice to just pop the grain and darken the wood a bit.
PostPosted: Thu Aug 18, 2016 5:13 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I leave mine unfinished and sanded to low grit.
I found that when I sanded ebony or rosewood bridges to anything above 320 that the surface was very susceptible to marks from even light contact like a finger nail brushing across the surface, which leaves something that looks like a burnish mark. The higher the grit (sandpaper or micro mesh) the worse it was. It really bugged me so I stopped sanding to high grit. Do those who sand their bridges to fine grits see that happen? Maybe oil or wax would prevent that?
These users thanked the author J De Rocher for the post: kencierp (Fri Aug 19, 2016 8:47 am)
PostPosted: Thu Aug 18, 2016 5:39 pm
First name: William
Last Name: Snyder
City: Brooklyn
I have gone with no finish/high grit sand and buff but usually I wet sand with waterlox @4-600 grit then work my way up to the finer grit micro mesh or micro finishing papers. Fills most of the pores and gives a nice luster without really looking like it has finish on it.
I've had to remove a couple that I've done this to and the heat does dull things but nothing that 2-3min with fine paper or buffing can't fix.
PostPosted: Thu Aug 18, 2016 6:39 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
For mine, especially ebony, I sand to 400 or 600 no more, then a quick buff on a couple of small (4" or so) buffs
on the drill press. Ebony will blacken them so I use them only for this purpose. Cheap, less than $10 each from hardware
store.
These users thanked the author Ken Lewis for the post: kencierp (Fri Aug 19, 2016 8:47 am)
PostPosted: Thu Aug 18, 2016 6:44 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
Here is a link to a few done this way
viewtopic.php?f=10117&t=45549
Last picture down.
Ken
PostPosted: Thu Aug 18, 2016 6:47 pm
Yep. Any moisture dulls it too, so finger prints show. That's why I started adding shellac.
These users thanked the author DennisK for the post: J De Rocher (Thu Aug 18, 2016 7:40 pm)
PostPosted: Thu Aug 18, 2016 7:26 pm
Last Name: Beaver
City: Lake Forest
I sand mine to a nice sheen then about two or three coats of fingerboard oil. Nothing on the gluing surface of course. It eliminates the 'moisture makes it matte' problem. And it is easy to touch up.
Joe Beaver
Maker of Sawdust
PostPosted: Fri Aug 19, 2016 3:41 am
Sand to 600 max, 2/3 applications fingerboard oil with paper towel, quick buff with cotton wheel.
PostPosted: Fri Aug 19, 2016 7:01 am
Always used 600 grit, then canning wax on bridges and F/B's. Rub it on and rub it in with a cloth. Done.
These users thanked the author Haans for the post: kencierp (Fri Aug 19, 2016 8:48 am)
Double post.
PostPosted: Fri Aug 19, 2016 2:22 pm
Same as Hesh for Rosewood. For ebony I just sand and polish it before I glue it on.
Users browsing this forum: Michaeldc and 10 guests
